- Joined
- Sep 4, 2012
- Messages
- 10
- Reaction score
- 3
i want to report to you guys that if i change the auth id of my extension with the same extension number, after a random time 3CX restore the default value.
For example, if i've an extension with number 217 and i create a generic phone, the default Auth ID is something like "Ah28e1!83".
If i change the auth id string with "217" and i register the phone (and it works), maybe the next day the phone doesn't work because 3CX restore the old value "Ah28e1!83".
I don't know if it's normal, but if i cannot change the auth id, 3cx should disable the edit of this field.
