Change default Operator Extension
cafecom
I wasnt paying enough attention while doing an installation and accidentally left the default operator extension as 000.
Being based in Australia 000 is an emergency number which I cannot assign due to the above.
Is it possible to change the default operator number or do I need to reinstall?
You can change it under "Settings" on the bottom right, then click on the "General" button. Operator extension will appear right at the top in this menu.
Reactions: Connexium
If you have no operator (human one :p) you can set a dummy extension in this field and manage settings in extension according to what you want to do with calls coming back to operator.
[email protected].
