Change FromHostPart in SIP format
carlosyr
I have a Generic SIP Provider that requires a domain to be included in the "From" section of the SIP Header. For example:
Code:
From: "+123456789"<sip:[email protected]:5060>;tag=xxxxxx
This domain is not a public domain, so I currently resolve this by using the split DNS technique and setting the remote host part with the DNS.
I would like to achieve the same outcome using only 3CX, eliminating the need for split DNS.
So far, I have attempted to create a custom template without success. I downloaded the template and tried to edit the `FromHostPart` parameter, but it didn't work:
XML:
<field name="ParameterOut" custom="custom.from.domain" parameter="FromHostPart">$GWHostPort</field>
Do you have any advice?
You can try this:
Code:
<field name="ParameterOut" custom="custom.from.domain" parameter="FromHostPart">$CustomField</field>
Hi YiannisH_3cx,
That did the trick!
Thanks for your help; I really mean it.
Reactions: YiannisH_3CX
Glad I could assist
