Solved Change of Partner Linking - How to ?
wavetel1
Ive been asked to take over from another partnership of a On Prems system. The licence is expiring shortly . Whats the best approach. I have the admin login and its currently running v18 .
Can I unlink it from the admin console and relink to my partnership through there ? Or does the customer need to login through their Portal and initiate it from there ?
Thanks in advance .
You can do it from the management console.
Reactions: jed and Evolute IT
All sorted . Easy . You can also login the customers portal (or they can) and change the Partner ID in there. It then unlinks the old one and shifts it to the new one nominated .
Reactions: NicholasP_3CX
NetworkActive
