Change Static Public IP
Louis J.
Forum User
Hi all,
Just trying to determine the best method for changing the static public IP on a Windows 3CX install running v16.0.1.273.
Thanks in advance :)
Hi all,
Simply change it under Settings -> Network.
Then, FQDN should update after 6h (Std, Pro) or 5min (Ent).
Hi Louis,
Out of network IP change , you can push PBX update to latest V16.2
[email protected].
