Solved Change the Conference Gateway Number
Sunny_99
Hi All,
i would like to change the extension number of the Conference Gateway.
By default it is set to 70, but i want to change that to a higher number, e.g. 98. I have 2 questions:
1) Is it possible to change the number?
2) If yes, what changes are necessary?
I found two places related to the Conference Gateway. First is Settings -> Conference Settings -> Audio -> Conferenc Extension
Second is Settings -> Parameters -> DIALCODECONFGATEWAY
Is it enough to change both settings to e.g. 98 / 98* ?
All the best
Jens
Reactions: Samuel-
Just change the setting under Conference Extension, not the parameters settings - you will find changing it will update the pararmeter
Reactions: Samuel-
Hello Saqqara,
it worked as you mentioned. Thanks!
Jens
