Solved Chrome extension app
jofer
Gold Partner
Hi there
I have 3cx V16 with the latest updates on Windows 2016 server, this is for a large corporate customer. With lock down many users are forced to work from home. So we are using the webclient in chrome. But I would like to activate the chrome extension. For that you need to login using google account and install the app. Not all users have google account.
My question, is the chrome extension APP available to install without logging into the app store?
Yes, we installed it without having to have Google accounts for each user. We've since removed it as didn't see much use for it.
Where can I get the install file from?
It doesn't say 'Install 3CX Browser Extension' - Top left hand corner of the webclient?
yes it does thank you
gmacinit
