Cisco 7941G get's reorder while trying to dial extensions.
Karter
My 7941 works very well with incoming calls but whenever I try to dial an extension I get reorder after the first digit.
I suspect that it may be a set dialplan issue. Did you ever create one, and download to the set? Check the 3CX Activity Log to see if an Invite is even reaching 3CX.
Reactions: Karter
Thank you the problem was I Did not have a dial plan.
As I recall, when setting up that type set a few years ago. There is no initial dialplan, so digits are not sent until a timeout, or end of dialling "key" (can't recall what the end of dialling key was used). I don't recall digits being blocked at all.
Reactions: Karter
Ruben756
