Cisco SPA 502G and 508G default templates ?
Robertos
hi,
i have to customize template for the 502G and 508G SPA phones on latest Linux 3CX version.
I need to remove most line keys as they all show up as green and active on 508G
Which template do i need to modify in order to do this? Is it cisco.ph.xml ?
OK i have th correct template file but need to disable lines not in use. Not sure how t do this as they all lights are green for each 8 lines
gmacinit
