Clear Blacklist IP
AEnrico
Hi, I've update 3CX v14 to 15.5 and now I see over 2000 IP blacklisted.
Is it possible to clear all IP in one moment with single step? or with a command line?
Hello @AEnrico
Please note that there is no Delete All button for clearing the blacklist. You will need to select them by clicking on the them and then use the delete on the top to delete them.
ok, so I know what to do for the next 2 hours.
Thank you.
but when the PBX as blocked something I would not delete just the enties, they are there for a reason...
PS, whitelist is triggered above blacklist....
I have amassed a large IP blacklist myself, but i would certainly not consider deleting any of them. They were added for a reason, primarily because they were a repeat offender. Unless some of the blacklisted IPs are causing some sort of remote access issue, I'd leave them in place.
If you delete them, you'll just have to start over again.
If these are local IPs, and a result of the upgrade, then consider white-listing the local LAN.
Reactions: YiannisH_3CX
johnblackwood1
