ClickToCall a Ring Group
DanMay
Hi. I'm trying to set up Wordpress ClickToCall to work with a ring group instead of an extension. I read this post and tried setting this up in both the admin panel and on Wordpress directly using the plugin. The plugin works fine if I point it to an extension, but I still can't figure out how to get it to work with ring groups. When I tried in the admin settings panel, I wasn't able to select a ring group. I could select any extension that had already set up ClickToCall, but that was it. Manually keying in the extension for the ring group generated an error. Is there a way to make this work?
I'm wondering if this would require an intermediate extension, that was in turn forwarded to the ring group.
Roman Mazur
