Client 3cx android
sbsinfo67
SMB User
Hello
i have the latest android version 16.0.3.327
how can i delete all the recent calls
JGS
Hello @sbsinfo67
When you go in the recents tab, don't you have a cross in the top right of your screen ?
BTW latest version is 16.0.0.35, have you like a test version ?
Hi INDY_Mathieu
yes it's a beta version i wonder that there is no cross in the top
so i wait for the new release
Maybe they're working on an other way to make it or just forget :rolleyes:
@JohnS_3CX ?
They cannot be deleted from the phone, you can do it from your extension's webclient and it will also reflect on the Android device (pull down to refresh after deleting)
But in the actual 16.0.0.35 you've a cross doing it for all your history (of your own ext) when in the Webclient it's only one by one isn't it ?
Yes, its one by one. The 16.0.0.35 Android app which is the current stable will allow you to delete all
But you take this option off ? Is there any reason ?
This is beta, and the interface is redesigned, I do not know yet if this will be final but I have informed our development team.
Okay, good to know, thank you John
Reactions: JohnS_3CX
No members online now.
DejanMDS
