Cloud Hosted V18 and Nextiva Trunks
UnderdogAuto
Client currently has a Cloud hosted V18 server and is attempting to get Nextiva Trunks set up. Unfortunately we are uncertain what we are missing. Posting log here.. Have redacted our ip address as far as i can see. Thank you for your assistance.
04/22/2024 7:37:21 PM - Unregistered line: Lc:10001(@Nextiva[<sip:[email protected]:0/UDP>])
04/22/2024 7:37:21 PM - Removed registration for <sip:[email protected].*.*:5060;rinst=251d1d92720cb0b5>
04/22/2024 7:37:21 PM - [CM504007]: Next attempt to register Lc:10001(@Nextiva[<sip:[email protected]:0/UDP>]) is scheduled in 5 minute
04/22/2024 7:37:21 PM - [CM504005]: Registration failed for: Lc:10001(@Nextiva[<sip:[email protected]:0/UDP>]); Cause: Cause: 404 Not found/REGISTER from 208.89.108.104:5060
04/22/2024 7:37:21 PM - Sent registration forLc:10001(@Nextiva[<sip:[email protected]:0/UDP>]) :ClientReg Send Req REGISTER from 0.0.0.0:0 tid=2abf081c0795d355 Call-ID=9DmyZNzZa-6OreEifuth3w..:REGISTER sip:bt.voipdnsservers.com SIP/2.0Via: SIP/2.0/ ;branch=z9hG4bK-524287-1---2abf081c0795d355;rportMax-Forwards: 70Contact: <sip:[email protected].*.*:5060;rinstance=251d1d92720cb0b5>To: <sip:[email protected]>From: <sip:[email protected]>;tag=6ef31114Call-ID: 9DmyZNzZa-6OreEifuth3w..CSeq: 1 REGISTERExpires: 600Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REGISTER, SUBSCRIBE, NOTIFY, REFER, INFO, MESSAGE, UPDATESupported: replaces, timerContent-Length: 0
04/22/2024 7:37:21 PM - [CM504003]: Sent registration request for Lc:10001(@Nextiva[<sip:[email protected]:0/UDP>])
04/22/2024 7:00:46 PM - Default best-route IP is determined as *.*.*.*
04/22/2024 7:00:41 PM - Unregistered line: Lc:10001(@Nextiva[<sip:[email protected]:0/UDP>])
04/22/2024 7:00:41 PM - Removed registration for <sip:[email protected].*.*:5060;rinst=9214bf0ee19cc742>
04/22/2024 7:00:41 PM - [CM504007]: Next attempt to register Lc:10001(@Nextiva[<sip:[email protected]:0/UDP>]) is scheduled in 5 minute
04/22/2024 7:00:41 PM - [CM504005]: Registration failed for: Lc:10001(@Nextiva[<sip:[email protected]:0/UDP>]); Cause: Cause: 404 Not found/REGISTER from 208.89.108.104:5060
04/22/2024 7:00:41 PM - Sent registration forLc:10001(@Nextiva[<sip:[email protected]:0/UDP>]) :ClientReg Send Req REGISTER from 0.0.0.0:0 tid=636ff920c2549719 Call-ID=Zjy56cRmQXSi8MOHCLjGoA..:REGISTER sip:bt.voipdnsservers.com SIP/2.0Via: SIP/2.0/ ;branch=z9hG4bK-524287-1---636ff920c2549719;rportMax-Forwards: 70Contact: <sip:[email protected].*.*:5060;rinstance=9214bf0ee19cc742>To: <sip:[email protected]>From: <sip:[email protected]>;tag=440a7f45Call-ID: Zjy56cRmQXSi8MOHCLjGoA..CSeq: 1 REGISTERExpires: 600Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REGISTER, SUBSCRIBE, NOTIFY, REFER, INFO, MESSAGE, UPDATESupported: replaces, timerContent-Length: 0
04/22/2024 7:00:41 PM - [CM504003]: Sent registration request for Lc:10001(@Nextiva[<sip:[email protected]:0/UDP>])
04/22/2024 7:00:41 PM - Dev(1517504766):[sip:[email protected] / 6457984651]: PBX contact is public IP: <sip:[email protected].*.*:5060/UDP>
04/22/2024 7:00:41 PM - Lc:10001(@Nextiva[<sip:@:0/UDP>]) Resolving targets: primary - sip:bt.voipdnsservers.com, no secondary over +UDP+IPv4+IPv6
04/22/2024 7:00:41 PM - Line 10001 has been updated from DB
Have you also checked this with your provider?
SG_F7
