Company Phonebook
Heath
How do you edit the company phonebook... In researching I saw an old Forum that it was in Settings, but there is no option in Settings for company phonebook, I'm the administrator, and my entitlements has a checkmark to edit company phone book...
In 15.5., very simple just click on the Contacts (on the left)
Ok. That is not what I’m looking for. I guess I’m looking more for the Company Phonebook with all extentions. I just got a Yealink T48, and in phonebook under remote phonebook is the list of extention. There are names that are appearing that don’t have extensions and also a bunch of none. So I wanted to see how to delete these names that don’t exist and the none that are also listed
I would check your contacts, as the yealink address book only contains the mobile number (it ignores any other telephone fields) - you may have contacts with blank mobile numbers.
Do you see the same with the 3CX client or 3CX webclient
There is only 1 contact I have and that isn’t even appearing in this phone or any other phones that I have. All that is appearing is all the names and extensions and others that aren’t in my contacts or extensions including a bunch of none. None of those that are listing have cell phone numbers and are appearing with their extension numbers.
That all sounds very confusing.
The phone book that 3cx creates comprises of 2 parts
1) The Extension list with Name and Extension Number.
2) The Contact list with Name and Mobile Number.
(-> My guess is this is what you are seeing perhaps - contacts that the number is not entered under Mobile.)
Is your phone provisioned with the default template?
I went into the webgui and in directory there is the URL for the remote phonebook to the 3CX server. But in addition to the names and extensions, there is a bunch of ‘None’ listings with no phone numbers and other listings that are not listed in my extensions. And I only have 1 entry listed in contacts and that is not even appearing.
mschzias
