Conference REST API fetch organizer Join URL
m4aax
Today I am facing into a big issue for my system.
What I have developed is a whole call center system. Everything works fine with the telephony. Agents should now be able to set up a meeting for other agents. 5 minutes before a meeting starts, it should be possible as an organizer to click the “Join Meeting” button on the dashboard to join the meeting.
However, the meeting link from the organizer is not displayed anywhere in the REST API.
I would be happy about a quick solution. Thanks in advance.
Hello @m4aax, the API concept is that organizer receives the URL inside the webclient and via email.
I understand your needs and we're going to extend API replies in order to include organizer join URL in both /scheduled and /scheduled/meetingid APIs.
In the meanwhile you could consider using /adhoc API: you have a single URL and it's easier to manage.
Graham Robertson
