Connecting to more than one 3CX installation
giox069-b
Forum User
Hi, I need to be connected to two different 3CX installation with the Android client, but I have only one smartpone.The 3CX android client seems to be able to add more than one profile, but only one at a atime is active. I need two accounts to be active at the same time on the android 3CX client, to receive calls from both PBX. And if possible, to have both user directories/contacts.
If it's not posible, can anyone suggest a third party app?
Thank you
Hi @giox069-b,
I'm not aware of any 3rd party software to do this, but I'm just here to say that having 2 extensions logged in on one device at the same time is not possible.
If this is available to you, you can set up a bridge between these two 3CX and routing rules. Then it will be possible to receive calls from both to one internal call and call subscribers of any of them.
Reactions: Vali_3CX
DejanMDS
