Connection between 3CX and ASTERISK
eroe33
Gold Partner
Good morning
I ask for help, we have a configuration with 2 control units, a 3CX and an ASTERISK
we should interconnect them to make their respective extensions communicate
however on the ASTERISK control unit we must use PJSIP as a type of TRUNK
so here the problem arises
using the additional SIP mode with BRIDGE on the 3CX side rises correctly (but we cannot use it for corporate policies)
so I wanted to establish the BRIDGE with the ASTERISK and the TRUNK PJSIP, but I don't find how to do it
or if you have any other suggestions, not with BRIDGE but with GENERIC TRUNK on the 3CX side
thank you
thanks, i already find that, but in my case on ASTERISK i only use PJSIP.
In the link, use normal SIP
Unfortunately, using a bridge trunk to something other than another 3CX PBX is no longer supported. Probably too many related trouble tickets. The advantage of a Bridge trunk is that you could have another PBX register to 3CX, something most other PBXs are able do. It is a lot more difficult to get another PBX to allow a (generic) SIP trunk to register to it.
SG_F7
