Copied Debian VM to new location
BCS-Tech
New User
I got the Debian 10 ISO installed a couple of weeks ago at one location. It is running as a VM on and Windows server. Works good.
I exported the the VM and copied to a new location. Booted the VM and changed the static IP address. All of that is good.
But I don't seem to be able to change the settings of the 3CX SBC. The 3cxsbc.conf file says it is recreated on each reboot.
Is there a way to re-run the initial setup of 3CX SBC or to remove it and Re-install O I can put in the new information?
megalmazan
