Solved Copy number from Windows App Client
beta_Rigel
Hi there,
how do i copy a telephone number from 3CX? Often i have to send a number via Email to somebody else! Is there a quick way to do this?
thank you very much for your help
Hi @beta_Rigel,
If you click on your Calls section in the Web Client, you can select it and copy it out? What client are you using?
I am using the new windows electron client. Is there a way to copy the number in the phone book! Now i have to dial the number and quickly copy it. Maybe a copy function there would be useful.? Thanks for the help
Reactions: autohaus
Hi @beta_Rigel,
I understand, we'll take your input into consideration! For now however, it is going to have to be copied the way you mentioned. The alternative for now is having Management Console access to the contacts and copying from there.
Ok cool thank you
No problem @beta_Rigel, if you have any other issues feel free to open a new thread!
