- Joined
- Dec 4, 2019
- Messages
- 1
- Reaction score
- 0
Hi there,
I have came across the problem with the telephones with this update installed. Problem is specific to phones with enabled VLAN for PC port. Telephone is displaying "No Service" and you can't open the web console, ping it, also run ping from it e.g. gateway all packets are lost. But computer attached to it is in the right vlan and still working. Only solution I found is reset the phone to defaults, then downgrade to 44.84.0.140 and enable vlan for pc port. It's not ideal when you have almost 50 telephones.
Thank you
Thank you
