CPU high to 90-100%
Tanyapisist
We have an issue this everyday with our 3CX system using 100% cpu uasage.
Operating Systems windows server 2008 R2 SP1
Hi Tanyapisist,
Well although it is fairly outdated your OS is still supported by 3CX:
https://www.3cx.com/docs/manual/
Can you check your hardware specifications match up to the recommendations on the 3CX website for a the simultaneous calls of your system: https://www.3cx.com/docs/recommended-hardware-specifications-for-3cx/
Try running the following benchmarking tool on your server (Outside of working hours of course).
http://ssd.userbenchmark.com/
It'll tell you how the components on your machine are running and thus helping you identify whether this is a hardware issue or not.
Also what 3CX version are you running?
Hi Tanyapisist,
Dear support 3cx
Vmware version 5.1
Intel(R) Xeon E5-2650 @2.0G (4processors)
Ram 16GB
HDD 1TB
OS Windows Server 2008 R2 Standard Service pack 1 64bit
3cx Version 15.5.10244.4
How many extensions do you have and what devices are you using for those extensions? Are you using ip phones or 3CX clients? Also is this a busy system?
195 extensions
1 Yealink ip phone and all using 3cx clients
No busy system
Can you check the 3CX services and see what service is causing the CPU usage? Also is this a dedicated machine for the PBX?
4qx
Yes, machine for PBX
Can you try restating the management console service and let me know if that reduces the load o the CPU?
Hi, did you ever get to the bottom of this? I see the same issue with one of my installs. It is the PhoneSystem 01 SIP Server that is running around 96% for a very long time. Restarting the server drops it down to normal.
I would recommend creating a ticket regarding this with our support department so they can take a look at the logs of the system and see what is causing the issue.
Herm77
