Creating and Deleting Users via cURL in 3CX – Department Assignment Issue
VUSALDADASHOV
Gold Partner
Hi everyone,
I'm trying to create users in 3CX via the API using cURL. The user gets created successfully, but I noticed that it is created without any department assigned.
Here’s the command I’m using:
Code:
TOKEN=$(curl -sk -X POST "https://3cx.domain.tld:5001/connect/token" -H "Content-Type: application/x-www-form-urlencoded" -d "client_id=MYCLIENTID&client_secret=MYCLIENTSECRET&grant_type=client_credentials" | jq -r .access_token)
curl -sk -X POST "https://3cx.domain.tld:5001/xapi/v1/Users" -H "Authorization: Bearer $TOKEN" -H "Content-Type: application/json" \
  -d @- <<EOF
  "Number": "$NUMBER",
  "Enable2FA": false,
  "Require2FA": false,
  "MyPhoneShowRecordings": true,
  "MyPhoneAllowDeleteRecordings": false,
  "MyPhoneHideForwardings": false,
  "MyPhonePush": true,
  "RecordCalls": true,
  "AllowOwnRecordings": true,
  "RecordExternalCallsOnly": true,
  "RecordEmailNotify": false,
  "FirstName": "$FIRST_NAME",
  "LastName": "$LAST_NAME",
  "DisplayName": "$FIRST_NAME $LAST_NAME",
  "EmailAddress": "$EMAIL",
  "Mobile": "$MOBILE",
  "WebMeetingFriendlyName": "$SAMACCOUNTIDWITHOUTDOT",
  "VMEmailOptions": "None",
  "VMPIN": "$NUMBER",
  "Language": "en",
  "SendEmailMissedCalls": false
EOF
I’ve attached a screenshot showing the user created without a department.
Questions:
  1. How can I assign a department (PrimaryGroupId) when creating a user via the API? When i'm adding PrimaryGroupId paramenter i get this error
    Code:
    {"error":{"code":"","message":"PrimaryGroupId:\nWARNINGS.XAPI.NOT_FOUND","details":[{"code":"","message":"WARNINGS.XAPI.NOT_FOUND","target":"PrimaryGroupId"}]}}
  2. What is the correct method to delete a user or at least disable it via the API? I tried using DELETE /Users/{id} but it didn’t work, and also Pbx.BatchDelete returned an error.
Thanks in advance!
JSON:
"Groups": [{"GroupId": 5000, "Rights": {"RoleName": "users"}}]
You should know the group number. You can get it beforehand through another GET request.
Remember:
If you want to know how 3CX does this, use a suitable browser and use its developer tools to track the API communication between the browser and 3CX. It tells you everything, including what's needed to delete a user with Pbx.BatchDelete ...
JSON:
Remember:
I know the group number, I can GET it
it is static. 149
I found how to do that
Code:
vusald@VUSALD-DELL:~$ curl -sk -X PATCH "https://3cx.domain.tld:5001/xapi/v1/Users($USERID)" \
  -H "Authorization: Bearer $TOKEN" \
  -H "OData-Version: 4.0" \
  -H "Prefer: return=representation" \
  -d @- <<EOF
  "Id": $USERID,
  "Groups": [
      "@odata.type": "#Pbx.UserGroup",
      "GroupId": $GROUPID,
      "Rights": { "RoleName": "users" }
EOF
vusald@VUSALD-DELL:~$ curl -sk "https://3cx.domain.tld:5001/xapi/v1/Users($USERID)?\$select=Id,Number&\$expand=Groups(\$select=GroupId,Rights)" \
  -H "Authorization: Bearer $TOKEN" | jq .
  "@odata.context": "https://3cx.domain.tld:5001/xapi/v1/$metadata#Users(Id,Number,Groups(GroupId,Rights))/$entity",
  "Number": "571",
  "Id": 307,
  "Groups": [
      "GroupId": 149
Now will this change in next updates ?)
and this one removes
Code:
curl -sk -X DELETE "https://3cxx.domain.tld:5001/xapi/v1/Users($USERID)" -H "Authorization: Bearer $TOKEN" -H "OData-Version: 4.0" -w "\nHTTP %{http_code}\n"
No members online now.
SamadMYK
