CRM Contact Open Mode on Windows Client
ckobayashi
We are using the Windows client and I am see in Settings that there is an Integration option to show Contact on Ring:
However in this thread I read that the Windows app will not create contact popups: https://www.3cx.com/community/threads/unable-to-get-crm-popping-up.75743/
If the Windows client is incapable of opening a contact in CRM why is the integration option available as displayed above? We would like the Windows client to create contact screen pops just as the 3CX browser extension does. For technical reasons we cannot use the browser extension for these users.
Is there any way the Windows client can create CRM screen pops when a call comes in?
Thank you!
This is due to the fact that the 3CX Windows App only works with client side CRM integrations as seen in "Settings >> CRM Integration" which is now a Legacy feature:
That said, if indeed you are using a Server Side CRM integration you will have to use the 3CX Webclient for this feature.
gmacinit
