CRM Generator SOAP
mikeodo
Titanium Partner
Does the CRM integration only support REST or SOAP?
You can use REST or SOAP, as you wish. When using SOAP, you need to manually build the XML to send in the request. There is no help on creating this based on the WSDL for example, it's a manual procedure, however totally possible.
Senergia
