CSF with Uelastix on Raspberry
Amphibian
Maybe some one can advise me?
I installed Uelastix on Raspberry Pi this date, then installed CSF, when setting up csf upon submitting I get the following errors and csf won't start:
"" iptables v1.4.14: can't initialize iptables table `filter': Table does not exist (do you need to insmod?)
Perhaps iptables or your kernel needs to be upgraded "".
In addition I received this within the csf.error file "" Error: iptables command [/sbin/iptables -v --policy INPUT DROP] failed, at line 791 in /usr/sbin/csf "".
Also, when I go through GUI and attempt to disable firewall under security I get the following "Firewall could not be deactivated". Could be the above problem is caused by the elastix firewall not being deactivated? Where might one look to manually disable elastix internal firewall?
Where to go what to do?
amphibian
RRusev
