Solved Current supported firmware for PA2?
MaxMCC
I Have a PA2, following this guide I changed my PA2's firmware to 2.4 (the fw in the folder the guide gave me) it was previously at 2.8 (which is what the PA2 came with), on the 3CX console both firmware's showed as being "Not Supported"
Does anyone know what firmware is "Supported" and where I can find it.
Click the box next to the device and hit the +firmware button so 3CX can push it to the right version.
Reactions: MaxMCC
Worked. Thank you for the help
