- Joined
- May 25, 2021
- Messages
- 2
- Reaction score
- 0
I try to configure out a custom CRM solution with the 3CX application (XML generator?) and i'm facing some difficulties. I'm only interest in the call journaling feature currently.
My goal is to display a "pop-up" on my CRM with the client information in. This pop-up was working historically with our old VOIP solution with some custom VBscript.
First of all, is there a condition on the contact lookup to run the "call journaling" ?
My tests prove me that if the contact lookup is KO, i never see an API call on my tools responsible of displaying the "pop-up". Is that the normal behaviour?
Secondly, when the contact lookup is OK (i hardcode it for the test) i have my "call journaling request" but this request happen at the end of the call and not at the begginning. Is that a miss-configuration on my side or is that just the way it should work?
In my CRM we tape the duration of a call, so i want the "call journaling request" to be post at the start of the call, is that possible?
Thanks for you help, if needed i can send you the XML i generated but i will hide my organisation information obviously.
