Solved Custom Provider Template
anonymouse
I'm trying to import a custom provider template but it keeps returning the error:
Uploaded template file has incorrect structure
header / template - This field is required
All I've done is copy/paste the exact contents of the Generic Voip Provider template and renamed it to test.pv.xml and tried to import the provider.
Version 20.0 Update 5 (Build 551 Release)
I can tell you that it works: export provider, edit provider, import provider template - everything is 1:1.
Did the editor or the system you're using make an unfavorable conversion during the copy/paste process?
Would you mind attaching the xml file you've imported?
EDIT: I see what I was doing wrong. I was copying/pasting the actual template from Admin > Advanced > Templates > Providers
It works when I export an existing trunk and then import.
Thank you!
