Datev support in V20
bit101
Hi togehter,
does anyone knows if V20 will support Datev integration again?
regards
Hi there.
This was only client-side integration and only available on the V16 Windows Legacy application and in the new V20 Windows application we don't have it.
Hi there.
Hi Oleg,
thanks for answering. The V16 Client works fine with V20 so far. So what happens when i update 3CX PBX from V18 to V20?
The existing clients should work, however, they are legacy and no further work in progress for them and we no longer maintain them too.
Hi Oleg,
thanks for that info. So we can be sure that Datev will not support in future releases of 3CX?
Is there the possibility to use Datev via Tapi integration?
For now, we do not have any information if this integration will be in the new application, so your only option now is to stay on that version.
ICTSupport@bedfordgirlssc
