Debian 9.4
islogic
I'm running 3CX 15.5.13103.5 on Debian 9.4 (stretch) on a Dell Core i3-2120 with 8GB RAM and I'm experiencing an issue where 3CX attempts to restart at 06:47 each morning but fails with the error "Dec 4 06:49:35 chs3cx systemd[1]: 3CXCfgServ01.service: Main process exited, code=killed, status=6/ABRT"
The system was not routing calls and would not allow me into the console to investigate the issues & the only way of rectifying the problem quickly was a restart of the operating system.
A copy of some of the system log is below.
Can anyone please assist me?
Dec 4 06:47:02 chs3cx systemd[1]: Starting Daily apt upgrade and clean activities...
Dec 4 06:48:41 chs3cx systemd[1]: Reloading.
Dec 4 06:48:52 chs3cx systemd[1]: Reloading.
Dec 4 06:49:03 chs3cx systemd[1]: Stopping PostgreSQL Cluster 9.6-main...
Dec 4 06:49:04 chs3cx systemd[1]: Stopped PostgreSQL Cluster 9.6-main.
Dec 4 06:49:08 chs3cx systemd[1]: Reloading.
Dec 4 06:49:17 chs3cx kernel: [4922292.817972] device-mapper: uevent: version 1.0.3
Dec 4 06:49:17 chs3cx kernel: [4922292.818058] device-mapper: ioctl: 4.35.0-ioctl (2016-06-23) initialised: [email protected]
Dec 4 06:49:22 chs3cx kernel: [4922298.441104] SGI XFS with ACLs, security attributes, realtime, no debug enabled
Dec 4 06:49:22 chs3cx kernel: [4922298.444208] JFS: nTxBlock = 8192, nTxLock = 65536
Dec 4 06:49:22 chs3cx kernel: [4922298.453017] ntfs: driver 2.1.32 [Flags: R/O MODULE].
Dec 4 06:49:22 chs3cx kernel: [4922298.460983] QNX4 filesystem 0.2.3 registered.
Dec 4 06:49:22 chs3cx kernel: [4922298.529792] raid6: sse2x1 gen() 6348 MB/s
Dec 4 06:49:22 chs3cx kernel: [4922298.597796] raid6: sse2x1 xor() 6238 MB/s
Dec 4 06:49:23 chs3cx kernel: [4922298.665797] raid6: sse2x2 gen() 10828 MB/s
Dec 4 06:49:23 chs3cx kernel: [4922298.733804] raid6: sse2x2 xor() 7904 MB/s
Dec 4 06:49:23 chs3cx kernel: [4922298.801806] raid6: sse2x4 gen() 12705 MB/s
Dec 4 06:49:23 chs3cx kernel: [4922298.869812] raid6: sse2x4 xor() 9483 MB/s
Dec 4 06:49:23 chs3cx kernel: [4922298.869814] raid6: using algorithm sse2x4 gen() 12705 MB/s
Dec 4 06:49:23 chs3cx kernel: [4922298.869814] raid6: .... xor() 9483 MB/s, rmw enabled
Dec 4 06:49:23 chs3cx kernel: [4922298.869815] raid6: using ssse3x2 recovery algorithm
Dec 4 06:49:23 chs3cx kernel: [4922298.870098] xor: automatically using best checksumming function avx
Dec 4 06:49:23 chs3cx kernel: [4922298.874059] Btrfs loaded, crc32c=crc32c-intel
Dec 4 06:49:23 chs3cx kernel: [4922298.876826] fuse init (API version 7.26)
Dec 4 06:49:23 chs3cx systemd[1]: Mounting FUSE Control File System...
Dec 4 06:49:23 chs3cx systemd[1]: Mounted FUSE Control File System.
Dec 4 06:49:23 chs3cx os-prober: debug: running /usr/lib/os-probes/50mounted-tests on /dev/sda2
Dec 4 06:49:23 chs3cx 50mounted-tests: debug: /dev/sda2 type not recognised; skipping
Dec 4 06:49:23 chs3cx os-prober: debug: os detected by /usr/lib/os-probes/50mounted-tests
Dec 4 06:49:23 chs3cx os-prober: debug: /dev/sda5: is active swap
Dec 4 06:49:24 chs3cx systemd[1]: Reloading.
Dec 4 06:49:31 chs3cx systemd[1]: Reloading.
Dec 4 06:49:34 chs3cx systemd[1]: Starting 3CX PhoneSystem 01 Hotel Module...
Dec 4 06:49:34 chs3cx systemd[1]: Started 3CX PhoneSystem 01 Hotel Module.
Dec 4 06:49:35 chs3cx systemd[1]: 3CXCfgServ01.service: Unit entered failed state.
Dec 4 06:49:35 chs3cx systemd[1]: 3CXCfgServ01.service: Failed with result 'signal'.
Dec 4 06:49:37 chs3cx systemd[1]: Reloading.
Dec 4 06:49:37 chs3cx systemd[1]: Starting Daily apt download activities...
Dec 4 06:49:37 chs3cx systemd[1]: Stopping OpenBSD Secure Shell server...
Dec 4 06:49:37 chs3cx systemd[1]: Stopped OpenBSD Secure Shell server.
Dec 4 06:49:37 chs3cx systemd[1]: Starting OpenBSD Secure Shell server...
Dec 4 06:49:37 chs3cx systemd[1]: Started OpenBSD Secure Shell server.
Dec 4 06:49:38 chs3cx systemd[1]: Reloading.
Dec 4 06:49:38 chs3cx systemd[1]: Starting PostgreSQL Cluster 9.6-main...
Dec 4 06:49:40 chs3cx systemd[1]: Started PostgreSQL Cluster 9.6-main.
Dec 4 06:49:43 chs3cx systemd[1]: Started Daily apt upgrade and clean activities.
Dec 4 06:49:43 chs3cx systemd[1]: apt-daily-upgrade.timer: Adding 28min 42.126577s random time.
Dec 4 06:49:43 chs3cx systemd[1]: apt-daily-upgrade.timer: Adding 11min 43.178423s random time.
Dec 4 06:49:44 chs3cx systemd[1]: Started Daily apt download activities.
Dec 4 06:49:44 chs3cx systemd[1]: apt-daily.timer: Adding 7h 25min 1.600481s random time.
Dec 4 06:49:44 chs3cx systemd[1]: apt-daily.timer: Adding 50min 40.975137s random time.
Dec 4 06:55:01 chs3cx CRON[31591]: (root) CMD (command -v debian-sa1 > /dev/null && debian-sa1 1 1)
Dec 4 06:56:53 chs3cx kernel: [4922749.586280] iptables[SSH-brute]: IN=enp3s0 OUT= MAC=d4:be:d9:d2:e9:3b:e0:b9:e5:e5:26:bc:08:00 SRC=103.89.91.193 DST=192.168.1.10 LEN=52 TOS=0x02 PREC=0x00 TTL=115 ID=14532 PROTO=TCP SPT=55466 DPT=22 WINDOW=8192 RES=0x00 CWR ECE SYN URGP=0
Dec 4 06:56:56 chs3cx kernel: [4922752.583911] iptables[SSH-brute]: IN=enp3s0 OUT= MAC=d4:be:d9:d2:e9:3b:e0:b9:e5:e5:26:bc:08:00 SRC=103.89.91.193 DST=192.168.1.10 LEN=52 TOS=0x02 PREC=0x00 TTL=115 ID=14916 PROTO=TCP SPT=55466 DPT=22 WINDOW=8192 RES=0x00 CWR ECE SYN URGP=0
Wayne
You have to use the 3CX ISO with the debian version used on the ISO. You can not go to a different version of Debian
Thanks for the quick reply Nick. I did use the 3CX ISO to install the system, the read me from the ISO confirms the version.
Debian GNU/Linux 9.4.0 "Stretch" - Official amd64 NETINST
20180310-11:21
The only change I've made was to install NTP as I was experiencing system and handset registrations every so often.
The apt upgrade is not something that I'm kicking off.
Does this make sense?
Wayne
Hi Frank,
Thanks for your reply.
This is exactly what I did, I installed 3CX using the ISO downloaded from 3CX which was Debian 9.4 (stretch), downloaded and installed on the 27/07/2018.
I did install ConnectWise remote control client initially but removed it since it did not function correctly and the only other change has been the installation of NTP as advised in another 3CX thread as some found that this resolved an issue I was experiencing with extensions / system re-registrations during the day. Are you saying that the 3CX ISO release is 100% fixed i.e. you cannot add NTP etc? I've certainly not updated the system so I'm not sure where I've gone wrong?
Wayne
Hello @islogic
The first thing you should do is to upgrade to the latest version and see if you face any issues there. You also need to upgrade to avoid running into issues with activation. You can upgrade your PBX by following the guide below: https://www.3cx.com/blog/news/pbx-upgrade-update-6/
zipman
