Solved Debian self hosted cutsom FQDN issue
AK-47
Trainee Partner
Hi all, I'm trying to run up a self hosted debian 3CX image. Everything goes well except that no matter what configuration I try I always end up with a 3CX FQDN. I have setup DNS correctly both externally and internally, port forwards are in place, the Let's Encrypt SSL generates, and hostname and FQDN of local environment is all setup during the initial config. Yet after the post config tasks run, I end up with hostname.3cx.region.com.
I'll admit it's been perhaps a year since I've run up a self hosted deb image so I'm wondering if something has changed. Does anyone have any advice or help for this?
Thanks.
Hi Andrew,
Are you using the 3CX wizard ? If so, note that it only 3CX FQDNs not custom on hosted environment.
Also note that this can only be done on On-Premise machines and also with the correct license key (https://www.3cx.com/ordering/pricing/).
Reactions: AK-47
Of course. Thanks for the reminder.
mazet
