Default Audio Output Android App v16.6.2.89
redjade
Audio output defaults to Bluetooth and I cant locate a setting to change this.
I want to use earpiece as my default.
Any plans to add this feature? or is it hiding somewhere I haven't found?
Cheers
Hi @redjade,
When you say you want to use an earpiece as your default, do you mean a bluetooth connected device?
The Android operating system defaults audio to any bluetooth device that connects to it, and if another connects it will use the last connected one though you should be able to cycle through which devices are connected.
EDIT:
We plan to add this functionality built-in to 3CX in the future, but for now you'll have to manage it on the phone's OS.
Hi @redjade,
EDIT:
Thanks for the reply.
I actually was referring to the phones earpiece.
It is annoying that I have to change the output for every call I make.
Cheers
Yes, I understand. There is no default just yet. However with 1 tap you can switch between bluetooth and earpiece, like you currently have to on an operating system call or other popular programs.
SupportRock
