Default Internet facing IP Address. (Default gateway) - IP mismatch
dblum
Forum User
Is there a reason when logging into the 3cx site for the server it will randomly say IP mismatch and when I go to the network settings to change I only have to choose OK and then the status page will show up properly? The info screen will show ip mismatch and no license but as soon as I make the change it shows it is working again?
Has this just started happening?
Have you tried a reboot of the PBX?
Yes, we have rebooted in before and it comes back with same issue. It is behind a meraki appliance but dont think that should have anything to do with it unless 3cx servers reside in some european country that is blocked (if that is the case I would think it would not work at any time)
[email protected].
