Default mode of softphone
apitsos
SOHO User
Hi there!
I am facing a very common problem. The softphone is by default on the "Softphone" mode. In cases where a user has a hardware IP Phone (from Yealink, Fanvil, or whatever) and a softphone on his computer, sometimes prefer to put the softphone into the "Deskphone (CTI)" mode for obvious reasons. The thing is that after a restart of the softphone application or the computer the mode returns into the "default" status, which is "Softphone".
Is there a way to change the default status into "Deskphone" or even better to configure the application on a way to "remember" the last setting?
I am looking forward for your quick and accurate answers.
With kind regards,
Angelos Pitsos
Have you tried to change the default mode of the 3CX withing the management console
Select the extension under Users - Phone Provisioning - select 3CX App
Can can select IP Phone or Softphone
Reactions: VasilisV_3CX
Hi @Saqqara!
Thanks a lot for the tip. Unfortunately I can't check it right now, because I don't have yet access to the Management console. But I will check it as soon as I have access or I will ask the responsible person to check it.
With kind regards,
Angelos Pitsos
Sure thing @apitsos, keep us posted!
Silent_Guru
