- Joined
- Mar 31, 2022
- Messages
- 26
- Reaction score
- 3
When a call is made to a 3CX app on iOS/iPad, the caller hears 3 to 5 rings before the called device starts ringing.
This does not happen with Android Phones, there is no delay.
Here are some logs from both 3CX V18 and the app. Call is started by the user at 11:17:18
On the 3CX PBX server side:
On the iPhone side:
as you can see, the server sends notification on 11:17:19, but the iPhone receives it at 11:17:31
How can we remove that delay ?
Thank you
Code:
2024/05/27 11:17:16.945|25108|0039|Verb|Dequeue Updated.REGISTRATION.10032
2024/05/27 11:17:19.027|25108|0005|Verb|Enqueue Inserted.CONNECTION.951
2024/05/27 11:17:19.028|25108|0039|Verb|Dequeue Inserted.CONNECTION.951
2024/05/27 11:17:19.108|25108|0005|Verb|Enqueue Updated.REGISTRAR.10072
2024/05/27 11:17:19.108|25108|0062|Verb|Dequeue Updated.REGISTRAR.10072
2024/05/27 11:17:19.108|25108|0005|Verb|Enqueue Updated.REGISTRATION.10072
2024/05/27 11:17:19.108|25108|0062|Verb|Dequeue Updated.REGISTRATION.10072
2024/05/27 11:17:19.132|25108|0005|Verb|Enqueue Inserted.CONNECTION.952
2024/05/27 11:17:19.132|25108|0062|Verb|Dequeue Inserted.CONNECTION.952
2024/05/27 11:17:19.133|25108|0005|Verb|Enqueue Inserted.CONNECTION.953
2024/05/27 11:17:19.133|25108|0039|Verb|Dequeue Inserted.CONNECTION.953
2024/05/27 11:17:19.167|25108|0005|Verb|Enqueue Updated.CONNECTION.952
2024/05/27 11:17:19.167|25108|0039|Verb|Dequeue Updated.CONNECTION.952
2024/05/27 11:17:19.167|25108|0039|Info|Sending PUSH call-started for dn=647, replaces=szF6aoPxJQf48epT7Yn1Eg..;from-tag=7303b465;to-tag=f1448574, callerid=607, calle
rname=Luca Surname, callid=471, image=
2024/05/27 11:17:19.168|25108|0039|Info|IV: Sending PUSH to extension 647 device iPhone12,1iPhone
2024/05/27 11:17:19.694|25108|0005|Verb|Enqueue Updated.REGISTRAR.10031
2024/05/27 11:17:19.694|25108|0005|Verb|Enqueue Updated.REGISTRATION.10031
2024/05/27 11:17:19.694|25108|0062|Verb|Dequeue Updated.REGISTRAR.10031
2024/05/27 11:17:19.694|25108|0062|Verb|Dequeue Updated.REGISTRATION.10031
2024/05/27 11:17:19.695|25108|0005|Verb|Enqueue Updated.REGISTRAR.10015
2024/05/27 11:17:19.695|25108|0005|Verb|Enqueue Updated.REGISTRATION.10015
2024/05/27 11:17:19.695|25108|0062|Verb|Dequeue Updated.REGISTRAR.10015
2024/05/27 11:17:19.695|25108|0062|Verb|Dequeue Updated.REGISTRATION.1001
On the iPhone side:
Code:
11:15:25.663 VCE|bootstrap *** Destroying tunnel...
11:15:25.663 TNL|tunnel
---------- DESTROY TNL LIB ----------
11:15:25.663 TNL|tunnel destroyed
11:15:25.663 VCE|EMGR destroyed
11:17:31.122 [5343] [APP] =============== Application started ===================
11:17:31.171 [5343] VERBOSE MODE CHANGED:true
11:17:31.253 [5343] [SavedChats] save 0 on profile will change []
11:17:31.257 [5343] [SavedChats] read 0 from profile did change [1c561b7f-0ada-41f0-b43c-08399ad57110]
11:17:31.280 [5345] [Lifecycle] - Ringing calls: false
11:17:31.280 [5345] [Lifecycle] - calls updated, noCalls: true, backgroundTaskActive: false
11:17:31.281 [5345] [Lifecycle] - sceneActive: false && noCalls, stop the VCE?
11:17:31.293 [5345] [quickchat] new session created: NullConnection, active: false
11:17:31.349 [5345] [APP] daily push refresh background task scheduled at martedì 28 maggio 2024 alle ore 11:17:31 Ora legale dell’Europa centrale
11:17:31.467 [5345] Received push - callerId: 607, callerName: Luca Surname, replaces: szF6aoPxJQf48epT7Yn1Eg..;from-tag=7303b465;to-tag=f1448574, callId: 471, reason: 0
Thank you
