Delete 3CX PBX Express Cloud Trial
harald
I startet with the 3CX PBX Express Cloud Trial and migrated the phone system to a local installation. Now I have conflicting FQDNs (same license key in the cloud and the local install) and would like to delete the cloud installation. Is there a way to do this? Unfortunately I didnt find anything... Thanks in advance.
Regards, harald
Hello @harald
Please note that we will need to delete the instance for you. To do so however we will require some further information. Please check your inbox as i will send you a p.m. with the required information.
gmacinit
