Solved DID Bulk adding
dustycr
Hello everyone,
is it possible to bulk add a range of unique DID's in the SIP Trunk settings ?
I can only see a button with "Add Single DID" ? (I know that i can add a range like 1234560-70), but i have a lot of extension which all should have a unique DID where they can be called with.
Thanks in advance.
Not sure if this works, under Inbound Rules create one DDI rule
Export the settings, load the file into Excel - Create all the necessary DDI and import them back into Inbound rules.
This may also update the SIP trunk settings
Reactions: NickEmpireComm
Already tried this, but it didn't work for me. It said something like "index out of range", probably because the did's dont exist on the trunk.
It works, i have done it many times.
The DIDs don't have to be configured on the sip trunk/gateway they will dynamically add with a properly formatted CSV file.
Okay i tried it again and now it works.
All fields inside the csv had to bee filled.
devo.it
