Solved DID for specific extension
yvesf
Hosted 18.0 Update 2 (Build 314)Version
I am trying to use a specific DID in my trunk and assign it to a specific extension. Everything works fine for inbound calls that gets directed to the extension I want without passsing thru the Receptionnist. The problem is for outbound calls that do not show the ID I configure in the users extension under 'general'-'Outbound caller ID'
I tried changing the SIP field 'From: Display name' to be 'OutBoundCallerID OutBound caller id taken from Extension settings in management console'
Any help would be appreciated
Thanks,
Yves
Great to hear and glad you got it sorted out.
I will set this one as 'Solved'.
mazet
