Diffs in Conference Tabs?
Amphibian
Hey Team,
Looking for someone that can explain the diffs between the "PBX, PBX-Configuration, Conferences(located on left panel)" and "PBX, Conference (tab on top"?
They look pretty much the same except on my "PBX, Conference" it has "Add New Conference", when you select that you see a form that allows for setting up a new conference and within that form there is a "Conference Number" that is auto assigned. I don't see where you can assign an extension number to dial to enter new conference.
Amphibian
The left menu conference (freepbx) is static, that means, once created, they won't be deleted.
The tab top conference (elastix) is a temporary conference room, on which it has an expiry date, on which participants are emailed when thy are next to the start date, once the conference room expires, it is deleted.
jgutierrez,
Thank you sir.
amphibian
RRusev
