- Joined
- Jan 25, 2021
- Messages
- 10
- Reaction score
- 0
We're running into a problem with dialing out via voicemail.
Situation:
1. Configured an outbound rule, mapping calls with the 0 prefix through to route 1, callcentric. Strip digits=1. The dial plan on the ip phone on extension 000 matches this.
2. Direct calls initiated from the phone itself that are proceeded by 000 work without a problem, both for calls made across the Callcentric line as well as pstn calls.
3. Calls from the voicemail menu, option 3, also work fine providd the 0 prefixes is entered.
4. Here's where we run into problems. Attempting to call a voicemail back directly, option 4. Call transfer failed. I try making a second outbound rule that does not require a dial prefix, to make room for automatic replies. This rule has two routes configured to route through Callcentric. And for good measure, left it wide open for any extension to utilize this rule even though we're still going through 000. Still no luck. Call transfer failed.
I tried looking under voicemail preferences and there is nothing about adding a prefix to any calls made throug ha voicemail directly.
Is there any way to get this to work automaticaly, or are folks going to be stuck manually dialing out and trusting that the voicemail leaves their name and number (standard practice anyhow, so that in and of itself is not a problem), or is there a way to get the dial prefix to work automatically?
Thanks!
Situation:
Thanks!
