Solved Disable Blind Transfer on Web/Windows
dranjbar
Trainee Partner
Hi All,
Just thought I'd ask anyways but does anyone know a way to disable users from using Blind Transfer on the web app or windows app? I did some reason on the forums but couldnt find anything in relation to the web clients.
Daniyal
Hi @dranjbar,
I'm afraid this isn't available in the Web Client / Desktop App or the Windows Client.
Hi @dranjbar,
Ok no problem, it would cool to be able to disable Blind Transfers from the management consoles completely in the future.
Thanks for the confirmation anyways!
Sure thing @dranjbar, if you need anything else feel free to open a new thread!
megalmazan
