Disable outbound calls outside office hours
JCC_Admin
Since this option of "Disable outbound calls outside office hours" removed from admin console and moved to webclient we do not seems to have it set correctly.
In the webclient the option now can be found under Admin > Users > (Select a User) > then under "Status scheduler"
But to se the option "Disable outbound calls outside office hours" to enabled, you have to first enable the "Automatically switch status to available during office hours" so you can view the other option and enable it. But in this case the user status will change out of office hours.
Note that I tried to enable the sub option "Disable outbound calls outside office hours", then save the settings, then again disable "Automatically switch status to available during office hours" thinking that even if the other option is hidden it will remain active, but no, it disables it as well.
How can we just disable outboud calls outside office hours without having the user to change status automatically?
You can navigate from the Management Console to Users select a user go to options, and select the box " Disable External Calls", but please note that this will make it so the user will not be able to make any external calls until this option is disabled again by the Admin.
For this to be an automatic solution the only option available is to use the "Status Scheduler" feature you have also mentioned from the webclient.
@NikolasA_3CX yes I am aware of both options, but the first is for sure not usable, we cannot change this manually daily, and the second is now connected to Status Scheduler for some reason. When the option was previously available in Management Console we didn't have those issues, am not sure what what the idea behind moving it to rely on Status Scheduler! We were fine with it previously!
Reactions: karjune
TVV40
