- Joined
- Mar 15, 2019
- Messages
- 24
- Reaction score
- 6
It is not possible to disable the app completely unless you use the PBX on-premise. In which case you can block tunnel connections to the user and that will basically block apps. Otherwise, the only possible option is to disable Push.Hi,
We would like to be able to disable the 3CX smartphone app completely on a user based level.
Thank you, I know. We would like to see this feature.It is not possible to disable the app completely unless you use the PBX on-premise. In which case you can block tunnel connections to the user and that will basically block apps. Otherwise, the only possible option is to disable Push.
Very simple: do not install/provision client on user's smartphone. Or turn off the account on his smartphone.We would like to be able to disable the 3CX smartphone app completely on a user based level.
Founded in 2005, when VoIP was an emerging technology, 3CX has gone on to establish itself as a global leader in business communications.
