Unsupported Disabling Missed Calls Log
rayfield
Platinum Partner
I wanted to disable the Missed Call popup on a Fanvil X210 and found that it's easy to do through the phone's GUI interface. It's labeled Missed Call Log. This disables the Log and the popup display, which is fine.
But, I'd like to do it through a custom template so that I don't have to manually do this on every phone in a system.
So far, I've been unable to find anywhere in the 3CX Fanvil template where the Missed Call Log can be disabled.
Am I overlooking it, or is it not there?
John Rayfield, Jr.
Rayfield Communications
That was easy. Do you know where I can find a list of all of the possible 'commands' that can be used in the provisioning template for the Fanvil phones?
John Rayfield, Jr.
Thanks. That will help me out a lot. And I understand about not being supported by 3CX.
Do you know of a setting that will enable keypad tones when dialing with the handset on-hook? I know that if the handset is lifted off-hook, then tones are generated in the earpiece, but not in the speaker when on-hook.
John
This fits with what I've found so far.
John
Regarding Enabling/Disabling the Missed Call Log, that works fine.
But, I would like to leave the Missed Call Log Enabled, and Disable the Missed Call Popup.
I found the parameter in the X210's configuration file, but when I try to add it into what appears to be the proper section in the 3CX provisioning template, it does not work. I made sure to include "X210" in the list of phones in the IF/END IF section where that parameter should go (UI_MAINTAIN_CONFIG_MODULE).
Any suggestions?
John Rayfield, Jr.
That worked fine.
I tried this first:
{IF ua=X3U,X3SG,X3SP_Pro,X3SP_Lite,X3SG_Pro,X3SG_Lite,X3U_Pro, X210}
<UI_MAINTAIN_CONFIG_MODULE>
<Idle_Time_Font_Color>0xffffff</Idle_Time_Font_Color>
<Missed_Call_Popup>0</Missed_Call_Popup>
{ENDIF}
And it did not work. Any idea why?
John
Good catch! The littlest things..... :)
Reactions: imperator
LeeonLau
