documentation current? Vodafone Germany Sip-Trunk
nobody
https://www.3cx.de/blog/vodafone-deutschland/
Is this current and correct?
I have difficulties setting up a working connection. The documentaton also seems only to be for a different version than what VF sent to me.
I have no password. Authentication is done solely by the IP Adress.
After I entered the sip domain supplied by vodafone: xyz.ngn.vodafone.de in the Request LineURI:Host Part I am able to make calls, but when I try to receive a call, I geht only a number unknown at the callers side, and just nothing when I run a wireshark filter with port 5060. I would expect an invite, maybe not from the Vodafone proxy but from an address in the near of it. But nothing? If not to port 5060 where else could the pbx be notified that someone is ringing?
Please update the docs regarding Vodafone.
Hello @nobody
Please note that the supported and tested service from Vodafone Germany is Register based and you should use a registered based trunk if possible.
The fact that nothing is arriving on the PBX means that Vodafone is not sending the call to you. By the time nothing arrives at the PBX there is nothing we can do from our side. You need to speak with the provider and ask them to help you.
Something happend what I did never expect: I spoke to a friendly and competent guy at VF, and indeed, the incoming routing was not correct. He fixed that in a few minuntes, and it looks like basic things are working now.
Amazing. The normal way (if this had been the deutsche telekom), would have been to open a ticket, wait for about 1 week, never get an answer or, one day later an anonymous SMS stating that it is fixed but actually nothing would have changed.
Regarding the documentation:It is not clear that the documentation is only for the "register" variant:
It reads:
Vodafone bietet Ihre SIP Trunks je nach Bestellung auf Basis von
  • IP Authentifizierung
  • Digest Authentifizierung
an. Beide Optionen können im 3CX Phone System genutzt werden
Nothing about only the register option is supported. I have the variant with "IP Authentification", for me this is the same as the "not register" - correct? The 3CX article tells that both option can be used with the 3CX phone system. But the documentation does not tell any further about the option with the IP authentification. Maybe update the article a little to make things clearer to understand?
Glad to see the issue has been resolved and thank you for updating the post with your solution.
You are correct the guide needs to be updated to a more current version as it states that both versions are supported.
The template in the PBX however is only for registered based trunks and that is what is stated in our website: https://www.3cx.com/partners/sip-trunks/deutschland/
gmacinit
