does Call Control API v16 work for create WebMeeting links?
alvaro.parra
Hi for all members and support team,
I would like to know If I can use Call Control API v16, in order to handle the creation of links for webmeetings.
thanks,
Alvaro
thanks,
Alvaro
Nope
Hi Alvaro,
Nope, this is not possible. You can only create them using your 3CX Webclient or Windows Client
Hi @JohnS_3CX ,
Is there any else API besides the plugin in wordpress to handle invitacions and links to webinar?
thanks
Hi Alvaro,
Not that I'm aware of. Webinars are a bit different, the user signs up, versus Webmeetings where you must invite someone.
What was your original goal for which you wanted an API ?
The idea is something more like an external CRUD over Webinars
I see. I'm afraid that will not be possible, you must manage it via 3CX directly
Subject1725
