E-Receptionist - New to system
Santosh Nellutla
Hi All,
I am looking to launch a business similar ereceptionist.co.uk in UK. Am i in the right place to do this, if so please can someone guide me on what online training will i be required and what type of 3CX software i should go for ?
Santosh
Hello @Santosh Nellutla
The type of software you will need depends on your needs and requirements. You can see what is included in every edition here: https://www.3cx.com/ordering/pricing/
For training there is a lot of material online to get you started. I would recommend starting with the academy that covers everything you need to install and maintain a 3CX system
https://www.3cx.com/3cxacademy/
There are also live webinars that take you through the functions of the PBX
https://www.3cx.com/blog/event-trainings/
Hi Yiannish,
Thank you for your speedy reply. But first, i would like to know whether it is possible to achieve the requirement with 3CX, as mentioned earlier i am looking to go exactly as ereceptionist.co.uk model.
Santosh
As i am not aware on what the mentioned service does i am not the right person to answer that. Perhaps another forum user with knowledge on ereceptionist can provide more information.
similar but not the same.
Would say 3CX does not fit your requirements,
gmacinit
