E911 Settings inside of 3CX
RoyJ
New User
For reference: I am now using the SMB plan hosted with 3CX.
I am trying to set up the system so that 911 will work if needed, but I am unable to find the settings as described in the video I found. Could someone please point me in the right direction? I do know about submitting e911 info to the SIP Trunk Provider.
Thank you kindly for your help,
Hi there.
In that case, for FREE/SMB you will need to add regular outbound rules, as indeed it's not the same as when you configure and administrate your own Phonesystem.
@CamNYC Hi there.
Is your video for the reference of the first reply?
As in SMB/Free, you dont have emergency calls access, as it is a shared server and regular outbound rules needs to be created in that case .
Hi there,
If you mean that the question about E911 setup on 3CX should be in a new thread, I can do that. I thought it was related to this thread, but if you can't answer it here, please let me know, and I will post it separately. Thanks.
Hi there,
If its related to Free or SMB than you dont have any options to configure E911.
Reactions: Nathan@Voxtelesys
great thanks.
Reactions: bitn2
just to clarify, is there any difference in how 3CX is configured for 911 compared to E911?
That's not 3cx it's your provider. 3cx are just sending your call to your provider and your provider your data to 911.
There are 20 buildings, each with its own DID and address. The SIP provider will send the address associated with the specific DID for each building. However, it's unclear how they would know detailed E911 information like the specific floor or office. Is this something that needs to be configured in 3CX? This has not yet been clarified.
No, that's your provider who is sending this data. You have to configure just the correct dids to your extensions.
Reactions: CamNYC
SG_F7
