Echo on inbound call to Galaxy A21
mattdarnell
Gold Partner
Here is what we have discovered:
  • Inbound 3cx client calls to that phone have an echo
  • Outbound 3cx client calls from that phone are normal.
  • Switching to wifi on that phone has no effect.
  • Phone had a case. Taking case off has no effect.
Other clients on the same instance do not exhibit the same behavior.
Is there an echo troubleshooting guide?
Mahalo,
Matt
Hi @mattdarnell
Thanks for your feedback
Could you kindly try changing the Audio subsystem api?
Android App Settings (top left hamburger menu) > Settings > Advanced > Audio Options > Audio subsystem API > Select option Automatic (Android OS decides between AAudio and OpenSL)
Thomas
Thank you, we will try that.
Finatra.us
