Effective Gamma Template to allow International Calling
Alex Nicol
Hi All
Do any of the Collective have a setup as below and if so, would they be willing to share their settings?
Gamma SIP Trunk
Azure Hosted 3CX
Enterprise Edition V18.0 Update 8
Able to call Netherlands without getting 400 NOT Found Errors.
Further Notes:-
Yes International calling is enabled on the SIP
Yes, the Netherlands is an Allowed Destination on the 3CX
Yes the number is good, I checked on a different 3CX system and a mobile
I have another 3CX system using a JOLA SIP and can call the Netherlands without issue.
Yes I've contacted Gamma support, and they are being very helpful, but it's piecemeal - try this, try that, change this. etc.
I'm hoping that someone here has an already fully working system that I can exchange Outbound SIP settings with.
Kindest Regards
Alex Nicol
We have some Gamma Trunks in use (Germany). Maybe this helps...
  • Love
Reactions: Alex Nicol
Issue still remains. Thank you for your assistance though.
Call or Registration to 0031645956186@(Ln.10001@Gamma (3CX SIP Port 5060 required)) has failed. 8x.xxx.xx.xx1 replied: 404 Not Found; from IP:8x.xxx.xx.xx1:5060
SIP Server ID: 12294 10/18/2023 10:05:06 AM
Kindest Regards
Alex Nicol
This 404 is coming from Gamma... Please adjust your outgoing rules likes this (with your country code):
Sorted. Thank you. Resolved by removing all outbound rules and starting again.
Reactions: bitn2
I am glad you solved the problem, its allways important to have correct outbound rules.
Reactions: TheodorosG_3CX
Diogo Maia
